FME Server Architecture/Best Practices
  • Jul 6, 2016 2:39 PM UTC
  • 140 views
andrew_r
Forum|alt.badge.img+4
Does anyone have recommendations on training or white papers that go over the requirements and best practices for FME Server architecture? Looks like the training classes are geared towards building workspaces.
  • Jul 6, 2016 2:58 PM UTC
I recommend reading the first two chapters of the documentation, it's pretty good and it explains a lot of the concepts, it also gives good recommendations. There is also the chapter "FME Server architecture" that goes into quite a lot of detail.
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/Common/Home.htm
fmelizard
Forum|alt.badge.img+22
  • Jul 7, 2016 1:58 AM UTC
Here is a brief guide for producing an Optimized Enterprise Deployment of FME Server:
2016fmeserveroptimizeddeploymentguide.pdf
Many customers start simple and then decide on more sophisticated architectures later. This guide shows what is possible.
helmoet
Forum|alt.badge.img+8
  • Aug 18, 2017 1:20 PM UTC
chriswilson
Forum|alt.badge.img+29
  • Aug 20, 2017 9:50 PM UTC
This should be added to the architecture documentation, if you could please @aaronkoning.
