FME server 2022.2.6 installed, SSL and SSO SAML deployed all successful. Could not read write to sde MS SQL DB . Installed ArcGIS Server , registered data from sde , still could not connect to sde. FME server still works . Installed ArcGIS Webadaptor
  • Oct 10, 2023 11:34 PM UTC
  • 0 replies
  • 49 views
bcoshea
Installing ArcGIS Web adaptor IIS broke the Tomcat Web UI to FME server. Checked the Tomcat xml files to enable SSL 443 and SAML. All the config seems to be in place. "Unfortunately a backup or snapshot of the VM was not taken ahead of time." Anyone know how to get the UI back running? Pretty dumb mistake so there is not much dialog. But I have gone through setting up SSL with CA Cert and SAML.
