FME Options: Where the Default Paths are saved?
  • Sep 5, 2022 1:29 PM UTC
  • 105 views
massizurli
I need that every user who launches FME Workbench has set paths to a shared folder, in order to share connections to databases. However, I do not find where FME saves this information. In the Windws registry?
  • Sep 5, 2022 2:46 PM UTC
I suspect it's saved here:
HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine\Shared Resource Directory
hkingsbury
Forum|alt.badge.img+73
  • Sep 7, 2022 9:20 PM UTC
There is a key for the resources (as above) and also one for the named connections
[HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine]
"Shared Resource Directory"="\"\\\\path.local\\SAFE FME\\Shared_Resources\""
[HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine\Settings]
"Named Connection Directory"="\\\\path.local\\SAFE FME\\Shared_Resources\\Connections"
