FME License Sever service 1607 Error
  • March 12, 2018
  • 41 views
The FME License Sever service will not start with the License file provided.
See the below error when attempting to start the service.
I have gone through the troubleshooting steps in the install guide and the Safe.com knowledge base.
Can you please provided guidance on how to get past this error?
Output log:
17:50:16 (lmgrd) ----------------------------------------------- 17:50:16 (lmgrd) Please Note: 17:50:16 (lmgrd) 17:50:16 (lmgrd) This log is intended for debug purposes only. 17:50:16 (lmgrd) In order to capture accurate license 17:50:16 (lmgrd) usage data into an organized repository, 17:50:16 (lmgrd) please enable report logging. Use Flexera Software LLC's 17:50:16 (lmgrd) software license administration solution, 17:50:16 (lmgrd) FlexNet Manager, to readily gain visibility 17:50:16 (lmgrd) into license usage data and to create 17:50:16 (lmgrd) insightful reports on critical information like 17:50:16 (lmgrd) license availability and usage. FlexNet Manager 17:50:16 (lmgrd) can be fully automated to run these reports on 17:50:16 (lmgrd) schedule and can be used to track license 17:50:16 (lmgrd) servers and usage across a heterogeneous 17:50:16 (lmgrd) network of servers including Windows NT, Linux 17:50:16 (lmgrd) and UNIX. 17:50:16 (lmgrd) 17:50:16 (lmgrd) ----------------------------------------------- 17:50:16 (lmgrd) 17:50:16 (lmgrd) 17:50:16 (lmgrd) Server's System Date and Time: Mon Mar 12 2018 17:50:16 Eastern Daylight Time 17:50:16 (lmgrd) pid 1108 17:50:16 (lmgrd) SLOG: Summary LOG statistics is enabled. 17:50:16 (lmgrd) "5001-0301-12": Not a valid server hostname, exiting. 17:50:16 (lmgrd) Valid license server system hosts are: "HOSTNAME=5001-0301-12" 17:50:16 (lmgrd) Using license file "J:\\Apps\\FlexServer\\safe.lic"
danilo_fme
Forum|alt.badge.img+45
  • March 14, 2018
Hi @bstreeter
You can check this tutorial about error https://knowledge.safe.com/articles/543/floating-license-troubleshooting.html
Thanks,
Danilo
