FME Flow landing page stuck in refresh loop. Login not possible after reinstall.
  • Oct 23, 2023 2:25 PM UTC
  • 162 views
ewie
Hi community!
I installed FME Flow 2023.1.1.1 on Ubuntu 22.04 with installer [1]. I choose
setup type "Distributed / Fault Tolerant" to use an existing Postgres instance
according to [2]. I then set up the Postgres database according to [3].
I also changed proxyPort in /opt/fmeflow/Utilities/tomcat/conf/server.xml
to the correct port number. Then installed, enabled, and started the systemd
units according to [4].
Everything worked at this point and I could log in as admin and change the
password as required. I could also log out and log in as admin. I then
created a new admin user. When I logged out and try to log in as the new user
the landing page was stuck in an infinite refresh loop. I also deleted all
cookies which did not have any effect on the constant reloading.
The URL is https://view-db.vinci-energies.de/fmeserver/.
I uninstalled FME Flow, dropped the fmeserver database, and installed FME Flow
again as before. Now the landing page doesn't even prompt for the admin login
and instead looks like I'm already authenticated. But the menu for the user
settings does not open. I also checked the database connection and it works.
Also the GET requests for the following URLs now result in a connection reset.
https://view-db.vinci-energies.de/fmeserver/REST/token?cb=1698069629532
https://view-db.vinci-energies.de/fmeserver/REST/keepAlive?suppressBroadcastError=true&cb=1698069633532
A second reinstall did not have any effect and there's still no prompt for the
admin login.
Any ideas? I can also provide /opt/fmeflow/install.cfg and logs if necessary.
[1] https://downloads.safe.com/fme/2023/ubu_22/fme-flow-2023.1.1.1-b23636-linux-x64~ubuntu.22.04.run
[2] https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Run_the_Installer_Linux.htm
[3] https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Configure-FME-Flow-Database-on-Separate_Server-2-Tier.htm
[4] https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Configuring-FME-Flow-As-System-Service.htm
Erik
Best answer by ewie
The problem was the cache of our reverse proxy which apparently prevented FME Flow frontend from seeing the logout. Disabling the cache solved the issue.
merlinegeorge
Hello,
Would you be able to create a support case with the following information -
  • Tomcat and Core logs
  • How did you create the additional admin user- was it an imported user via SAML ? Or was it a system user ?
  • Did you try accessing the Web UI via the IP address instead of the FQDN and then try logging in? Does it still have the login looping behaviour?
  • When uninstalling please ensure this document was followed- https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Uninstall.htm and especially removed the file share and install directories in all distributed hosts.
ewie
  • Nov 2, 2023 11:38 PM UTC
