fme flow 2023.2 fmeserver.log warning on startup
  • Sep 18, 2025 9:30 AM UTC
  • 5 replies
  • 171 views
giosp
Forum|alt.badge.img+7
Dear all,
when fme flow start I still have this warning:
Thu-18-Sep-2025 03:36:23.523 AM   WARN     main   401881 : Parameter ENABLE_AUTOMATION_LOG_CLEANUP missing from config file. Using default value of: true
Thu-18-Sep-2025 03:36:23.523 AM WARN main 401881 : Parameter MAX_NUM_AUTOMATION_DEBUG_LOGS missing from config file. Using default value of: 200000
Thu-18-Sep-2025 03:36:23.523 AM WARN main 401881 : Parameter AUTOMATION_DEBUG_CLEANUP_INTERVAL missing from config file. Using default value of: 120
I’ve searched in the documentation but these parameters aren’t documented and I don’t know in which file I have to insert to prevent the warning in the fmeserver.log (common config or flow config).
Anyone has a suggestion?
Thanks, regards
Gio
skyleratsafe
Forum|alt.badge.img+9
Hi Gio,
Thanks for bringing this issue to our attention. I was able to reproduce this issue and got the same warning messages.
I have reached out to the development team for more insights and will keep you updated.
Best,
Skyler
skyleratsafe
Hi Gio,
I would like to provide some updates on these warning messages.
I found that this bug was reported before, and it should be fixed in FME build 23766. Could you confirm if the version you are using is older than this build?
Cheers,
Skyler
giosp
  • Oct 21, 2025 5:49 AM UTC
Sorry ​@skyleratsafe ,
I didn’t received an update on this post. Our installed version is 23764 .
Thanks,
regards
Gio
skyleratsafe
Hi Gio,
Sorry for the late reply. I was on holiday in Australia.
This issue was fixed in the newer version (FME build 23766), and an upgrade should fix the warning message issue.
Cheers,
Skyler
giosp
  • Nov 11, 2025 6:37 AM UTC
Thanks for the reply and welcome back 😅
Regards
Gio
