FME Desktop Install on Ubuntu 20.04 Failed
  • Nov 12, 2021 4:58 PM UTC
  • 7 replies
  • 179 views
bo
Forum|alt.badge.img+10
Hi Community!
Trying to install FME Desktop 2021.1.3.1 on Ubuntu 20.04.3 LTS to no avail.  Here is my install command and screen msg.
Any help is appreciated!
Bo
$ sudo dpkg -i fme-desktop-2021_2021.1.3.1.21635_ubuntu.18.04_amd64.deb
Selecting previously unselected package fme-desktop-2021.
(Reading database ... 357202 files and directories currently installed.)
Preparing to unpack fme-desktop-2021_2021.1.3.1.21635_ubuntu.18.04_amd64.deb ...
Unpacking fme-desktop-2021 (1:2021.1.3.1.21635~ubuntu.18.04) ...
dpkg: dependency problems prevent configuration of fme-desktop-2021:
 fme-desktop-2021 depends on libboost-regex1.65.1; however:
  Package libboost-regex1.65.1 is not installed.
 fme-desktop-2021 depends on libtcl8.5 (>= 8.5.0); however:
  Package libtcl8.5 is not installed.
dpkg: error processing package fme-desktop-2021 (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Warning: /usr/share/applications/safe-TransformWithFME-20820.desktop:10: ignoring empty entries in MimeType
Warning: /usr/share/applications/safe-TranslateWithFME-20820.desktop:10: ignoring empty entries in MimeType
Warning: /usr/share/applications/safe-ViewWithFMEDI-20820.desktop:10: ignoring empty entries in MimeType
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for shared-mime-info (1.15-1) ...
Errors were encountered while processing:
 fme-desktop-2021
DanAtSafe
Forum|alt.badge.img+23
  • Nov 12, 2021 5:35 PM UTC
Hi @Bo Guo​ I think you need to fix the dependencies. After running
try
sudo apt-get install -f
bo
  • Nov 12, 2021 6:11 PM UTC
Hi Dan!
Tried it without any luck.  Same issues with the following two packages.
When I tried to install the two packages separately I got
Package libboost-regex1.65.1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libboost-regex1.65.1' has no installation candidate
I am at a loss, not sure how to install not installable packages...
DanAtSafe
  • Nov 12, 2021 7:20 PM UTC
Hi @Bo Guo​ I should have noticed this before, but you're using the Ubuntu 18.04 installer! For some reason the Ubuntu 20.04 installer isn't listed at https://www.safe.com/support/downloads/#past-versions
You can get it here:
https://downloads.safe.com/fme/2021/fme-desktop-2021_2021.1.3.1.21635~ubuntu.20.04_amd64.deb
bo
  • Nov 12, 2021 8:16 PM UTC
Thanks Dan! I thought Safe only had 18.04 and some hacking was required... You saved my day!
I have a problem with installing the FME Desktop on Ubuntu 20.04.1
I receive the below error and was not able to solve it. Any ideas?
DanAtSafe
  • Jan 13, 2023 10:25 PM UTC
Hi @momeniiman​ Update Ubuntu and then try running
Thanks for your reply, Dan.
My ubuntu is up-to-date and after running the sudo apt-get install -f nothing changes. The same error
