FME Desktop 2014 install error on Windows Server 2008 SP1
  • Feb 18, 2014 2:44 PM UTC
  • 57 views
jon
Forum|alt.badge.img+5
I received this error when installing FME Desktop 2014 (20140120 - Build 14235 - WIN32) on Windows Server Standard 2008 SP1 (64 bit).  I clicked ok, and the installer finished without any other errors.  FME opens up and seems to be working correctly.  Should I be concerned about this?
I later looked at the system requirements for FME Desktop 2014 and noticed Windows Server 2008 SP2 or above is required.
http://www.safe.com/fme/fme-technology/fme-desktop/tech-specs/
Best answer by david_r
if things appear to work properly, I wouldn't worry unless you plan to use the Microsoft SQL Server native client as a reader or writer.
David
  • Feb 18, 2014 2:58 PM UTC
David
