Fatal error after upgrading to 2019
Hello,
after upgrading to FME 2019 from 2018 my workspace stopped working with error
Saving spatial index into file 'C:\\Users\\dusan\\AppData\\Local\\Temp\\wb-cache-Konacni_model_jul-KaOtqX\\Main_FeatureMerger_4 -1 298 fo 4 _lt_REJECTED_gt_ 0 82253bb54d545775c6265f622c6bd44f5854eccb.fsi'
Finished saving spatial index into file 'C:\\Users\\dusan\\AppData\\Local\\Temp\\wb-cache-Konacni_model_jul-KaOtqX\\Main_FeatureMerger_4 -1 298 fo 4 _lt_REJECTED_gt_ 0 82253bb54d545775c6265f622c6bd44f5854eccb.fsi'
Transcoding the binary string '1`\\xA8\\x83\\x191\\x02\\x00\\x00\\x00H\\xE1z$\\x04\\x14YA\\xB8\\x1E\\x85\\x8B\\x03\\x14YA\\xD7\\xA3p\\xAD\\xA4bRA333s\\xA5bRA\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x001\\x00\\x00\\x00\\x00\\x02\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\xF8\\x00\\x00\\x00\\x00\\x00\\x00\\xF8\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00\\x00' to another encoding can not be done
Can someone help me because this is the first time this happend to me.
Best answer by takashi
Hi @luckym, this looks like an internal bug on handling non-ASCII character encoding. I would recommend you to send a workspace and sample dataset which reproduce the error to Safe support, in order to let them closer look at this.
Report a Problem - select "Defect" in 2. Type of Inquiry
  • August 12, 2019
  • August 12, 2019
Thank you @takashi. I reported problem under case number C147344.
