Does the FME desktop setting control the logging in FME Server?
  • Oct 11, 2017 10:57 PM UTC
  • 94 views
Hi! I am using FME Desktop 2016.1 to publish workspaces to FME Server. I found that after I change the log settings in Tools menu-->Translation (for example, change to only log errors) and republish the workspace to FME Server, the log obtained by running it from FME Server will be different.
It seems a little bit odd to me, and I wasn't able to find help file about this after trying, so I just want to make sure I understand correctly the way it works: will the FME Desktop publish its desktop settings to FME server? or it is my misunderstanding?
Thank you!
Best answer by dustin
Log files created by FME Server jobs are written to the location that was specified upon the install of FME Server. The location specified in the workbench is ignored.
dustin
Forum|alt.badge.img+36
  • Oct 11, 2017 11:03 PM UTC
  • Oct 11, 2017 11:05 PM UTC
What about the Log Message Filter? such as the checkbox to control whether to log warnings or just log errors?
dustin
  • Oct 11, 2017 11:15 PM UTC
https://knowledge.safe.com/questions/20893/turning-off-the-info-logging-on-fme-server.html
According to this, you should be able to save the FMW, republish, and the settings should transfer to Server. Maybe this has changed since 2015?
  • Oct 11, 2017 11:24 PM UTC
In FME2016.1, the save button will still be grey after I change the log setting. I don't have experience in FME2015, maybe it was changed.
