Does the FME Desktop Professional Edition License Server log usage?
  • Mar 9, 2022 2:27 PM UTC
  • 51 views
Best answer by andreaatsafe
Hi @rob_nason​ ,
Our recommended approach for monitoring license use is by using commands using the lmutil tool. More details can be found in our documentation here.
Depending on your needs, you may want to look at this FME Hub template workspace that you could use as a building block for parsing the debug log of FlexLM.
-Andrea
andreaatsafe
Forum|alt.badge.img+17
  • Mar 9, 2022 5:22 PM UTC
Hi @rob_nason​ ,
-Andrea
