Determining if our FME Server license will host FME Server 2020.
  • May 5, 2020 2:27 PM UTC
  • 49 views
Howdy,
We're looking to upgrade our instances of FME Server. Our licensing uses the new model (web page portal, not FlexLM). The page has the serial # for the FME Server license but doesn't denote for what versions it will host. How do we determine this?
Thank-You,
Laramie
Best answer by redgeographics
If you have an active maintenance contract (check with your Safe partner or Safe directly) it should work.
Forum|alt.badge.img+63
