Can I use a basic proxy and version control?
  • May 28, 2020 10:42 PM UTC
  • 49 views
fmelizard
Forum|alt.badge.img+22
In FME Server, I am trying to use a basic proxy and version control but I am getting errors. How do I fix this?
Best answer by siennaatsafe
If you are seeing the following error, you'll have to do some additional configuration to get this to work.
1
õ_Could not push to remote repository._3586
õ_õ_Remote ref update was rejected:
https://github.com/test.git: 407 Proxy Authentication Required_õ_õ
To be able to push to an external Version Control while using the Basic Proxy, the following configurations must be made:
  1. Open C:\Program Files\FMEServer\Server\processMonitorConfigCore.txt
  2. Look for # Start FME Server Core
  3. Add this to the START SYSTEM variable: -Djdk.http.auth.tunneling.disabledSchemes=
  4. Place this string anywhere near the -DJava arguments
  5. Restart Server
siennaatsafe
Forum|alt.badge.img+12
  • May 28, 2020 10:44 PM UTC
1
  5. Restart Server
