Attempting to Clip 1000+ Feature Classes in 100 Geodatabases
  • Oct 5, 2020 7:30 PM UTC
  • 127 views
Hi guys,
I have put together a FME list which generated I have 1000 feature classes after I located 100 geodatabases.
These 100 geodatabases are all in one folder.
I am just wondering if there is a easy way to clip this data to one standard. So clipper is one file which i want all 1000 feature classes to clip to.
Is there a quick and easy way to clip all 1000 feature classes and then output to exactly same featureclass and geodatabase name? I can do this by selecting schema and then clipping it but struggling to ensure the output is the same as the input in terms of geodatabase name/featureclass name and fields..
itsmatt
Forum|alt.badge.img+48
  • Oct 5, 2020 7:53 PM UTC
Should be pretty doable with a dynamic reader writer combo to preserve the schemas along with a Clipper (Set to single clipper mode). You can use a WorkspaceRunner to specify the input geodatabase and run in batch mode - you can use the PATH reader to get the file path for the WorkspaceRunner.
The FeatureReader could also be used with the Clipper feature as a spatial filter which will reduce the number of features read into FME. This might be the better option.
Let is know if you get stuck anywhere​
  • Oct 5, 2020 8:07 PM UTC
That is great, thanks for sharing. I will have a think about this, if it is clever enough to pick up all 100 geodatabases that would make my life a lot easier :)
itsmatt
  • Oct 5, 2020 8:10 PM UTC
Yeah should be able to. FME will keep track of the Schema, geometry type and Feature​ type name. There might be small differences so you'll want to run a few small test runs
