After upgrading to FME Server/Desktop to 2022.1 we are now having issues with the workbenches running SQLite with a joiner. The application stops on this transformer. Appears to connect them nothing after. Any ideas?
  • Aug 5, 2022 4:59 PM UTC
  • 39 views
keziaatsafe
Forum|alt.badge.img+8
Hi @brianapeters​ ,
Sorry you're running into this issue. It looks like the engine is crashing.  A coupe of questions to dig deeper:
  1. Is the workspace failing on both FME Desktop and FME Server?
  2. Are you able to share the workspace for me to take a look at?
  3. Can you also share the translation log from Desktop.
  4. Do  you have a successful job log from before the upgrade?
  5. When was this workspace created/authored?
I notice a warning message in your job log before the log cuts off:
SQLite Reader will run in compatibility mode. Legacy SQLite workspaces do not support unicode characters. There may be changes in behavior with table and/or column names. If names cannot be interpreted as unicode or with the system locale we will attempt a lossy conversion
Additionally, 0 features were retrieved after Database read was complete.  Do you know how many features are you expecting?
Thanks
-Kezia
