3-tier installation network port
  • Feb 10, 2023 3:47 PM UTC
  • 44 views
Hi eveyrone,
I'm trying to setup a 3-tier installation and I can't find the required network ports used by each component. I have a communication error between the engines and the core.
Error communicating with FME Server host xxxxx-fme-engine. Contact your FME Server administrator who can investigate the log files for further details.
I couldn't find anything useful in the logs
http://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/FME-Server-Ports.htm
Thank you
merlinegeorge
Hello,
These troubleshooting articles might be helpful-
https://community.safe.com/s/article/error-communicating-with-fme-server-host
https://community.safe.com/s/article/Known-Issue-Anydesk-Application
What HTTP error response code do you see when accessing the page? You can use the developer tools for further analysis.
Do you see this error on all Server Web UI pages?
Please see the list of ports that should be opened-
1) Web App server- Core communication- TCP 80 [or 443 if using HTTPS],7076,7071,7069,7081,7077,7075,7073
2) Core -FME Server DB Communication- 7082 [or another DB port being used]
3) Engine -FME Server DB Communication- 7082[or another DB port being used]
4) Web App -FME Server DB Communication- 7082[or another DB port being used]
5) Core-Engines communication- 7069,7070,7500
6) Engine - File share communication- 445,7079
7) Core- File share communication- 7079
8) Web App- File share communication- 7079
9) Engine - 7074,7073,6379
10) Load balancer- Web App communication (in case of fault-tolerant setup )- 7078,80 [or 443 if using HTTPS]
