XMLUpdater woes
  • Nov 28, 2019 1:26 PM UTC
  • 12 replies
  • 234 views
lifalin2016
Forum|alt.badge.img+42
Hi.
I haven't really used XML Updater before, but is now tasked with trying to update certain sub-elements i a large hierarchy. I'm trying to update QGIS project files (QGS).
I've extracted the needed replacement tag with content, and routes them in via the "update" connector. But I'm stumped wrt. how it's set up correctly.
My XPath is set to be this: //field[@name=fme:get-attribute("fieldname")]/editWidget
This is the location of the tags I want to update (replace) in the source XML file.
But it doesn't replace anything, and it errs with this somewhat cryptic message in the log:
XMLUpdater(XQueryFactory2): The following error occurred while executing query number 1:
XMLUpdater(XQueryFactory2): The following error occurred near line 2, column 26 of the query:
XMLUpdater(XQueryFactory2): invalid expression: syntax error, unexpected "type"
My replacement XML tag looks like this (example):
<editWidget type="TextEdit">
            <config>
              <Option type="Map">
                <Option name="IsMultiline" value="false" type="bool"></Option>
                <Option name="UseHtml" value="false" type="bool"></Option>
              </Option>
            </config>
          </editWidget>
I assume the "type" it's referring to is the type="Map" part of the replacement tag, but it looks like valid XML to me, so what's up with FME (or rather XQueryFactory) ?
Please help.
/Lars
Best answer by lifalin2016
Well, today it seems to be working.
Lastly I verified that my Xpath worked. I therefore looked at the replacement values, which were created by XMLFragmenter. It seems that the XMLUpdater cannot use these for replacement values as-is for some reason. I'll be making a feature request about this shortly.
I then inserted a StringSearch to extract the XML part, and loose the XML header line. That seems to be working, although I fails to see why this is needed, as the type setting states "XML/XQuery".
Anyhoo, the trick is to strip the replacement value of any XML overhead.
Forum|alt.badge.img+54
  • Nov 28, 2019 1:31 PM UTC
Can you share a sample of the xml you are attempting to update?
  • Nov 28, 2019 1:56 PM UTC
Have you tried constructing like this
 //field[@name=@Value(fieldname)]/editWidget
lifalin2016
  • Nov 28, 2019 2:10 PM UTC
Yep, fails the same way.
lifalin2016
  • Nov 28, 2019 2:14 PM UTC
I'm sorry, I can't. For one, it's huge (20K+ lines). And second, it's a regular project file from QGIS, that's easily available. And thirdly, it contains some in-house information, which QGIS insists must be stored in plain text :-(
lifalin2016
  • Nov 28, 2019 2:47 PM UTC
Further information:
When I use "Delete" instead of "Replace" (as update type), the tag gets deleted as expected.
So it seems that my XPath query works, so the error must be related to the replacement value.
However, that value is generated by an XMLFragmenter transformer, so it should be ok ?
  • Nov 28, 2019 3:47 PM UTC
I can insert that text into an xml file, which suggests that it's not the problem alone...
lifalin2016
  • Dec 3, 2019 10:41 AM UTC
I tried to update the XML as plain text, but that just html/xml encoded all "<" and ">" plus some other stuff (into &lt; &gt; etc. resp.).
lifalin2016
  • Dec 4, 2019 8:03 AM UTC
mathiku
Forum|alt.badge.img+8
  • Dec 13, 2023 6:52 PM UTC
I am struggling with the same thing over at https://community.safe.com/s/question/0D5OO000002qX8P0AU/xmlupdater-syntax-error-unexpected-qname
What did you do with the stringsearcher?
lifalin2016
  • Dec 14, 2023 7:11 AM UTC
Hi Mathiku.
Wow, this was an unexpected stroll down memory lane ;-)
I assume you mean, how did I get rid of the XML header in the replacement value, that blocked the usage in XmlUpdater ?
As fas as I can see and tell (in the ancient 2018 workspace), I used the StringSearcher like this:
billedeI basically just select anything in the proper xml tag (here: <editWidget + anything after it), and saves this into a variable to be used in XmlUpdater.
Hope this helps.
Cheers.
lifalin2016
  • Dec 14, 2023 7:12 AM UTC
Here's the XmlUpdater:
billede
mathiku
  • Dec 14, 2023 1:21 PM UTC
Thank you. That's similar to what I tried, but I got all these non-revealing errors. But the error might have been caused by something entirely else.
