XML tag order and whitespaces
  • Dec 5, 2017 9:01 AM UTC
  • 5 replies
  • 138 views
lazarlubomir
Forum|alt.badge.img+11
Hello everyone,
I try to export some XML data package via XML Templater. I have many conditions in tag filling and in cases, when tag is not filled, FME left there many whitespace, even if I use XML Formatter. You can check my syntax below:
The result is below of template is below:
Does anybody know, how to remove empty space and put object tag to the right level please?
Thank You so much!
Lubo
Best answer by david_r
The XMLFormatter has a setting called "Whitespace handling". Have you tried setting it to "Remove excess whitespace"?
  • Dec 5, 2017 9:05 AM UTC
How have you set the "Whitespace Handling" parameter in the XMLFormatter?
lazarlubomir
  • Dec 5, 2017 9:14 AM UTC
Thank You so much, my mistake :-( I missed this option and just reflected "Remove empty elements" and "Collapse empty elements"...
  • Dec 5, 2017 9:33 AM UTC
Good to hear you found those options :-)
For what it's worth, this template expression
<objects>
  <object>
  fme:get-attribute("value1")
  </object>
  <object>{
  fme:get-attribute("value2")
  }</object>
</objects>
generates this XML document.
<objects>
  <object>
  1
  </object>
  <object>2</object>
</objects>
  • Dec 5, 2017 10:15 AM UTC
<objects>
  <object>
  </object>
  <object>{
  }</object>
</objects>
<objects>
  <object>
  1
  </object>
  <object>2</object>
</objects>
You can cast the long value to a string value with this syntax.
xs:string(<the long value>)
