Writing a raster to column 0 Excel stretches raster - potential bug.
  • Jan 31, 2023 11:51 AM UTC
  • 56 views
spatialexjames
Forum|alt.badge.img+10
I'm finding that when you write a raster image to Excel while using the ExcelStyler to stretch the row height (e.g. 100), the raster will be stretched in the y-direction by a factor of about 7. This only occurs for the first column (xlsx_col_id = 0), and writes fine to other columns. Is someone able to confirm if this occurs on their version too?
It's possible to force a fix by adjusting the xlsx_raster_height to be about 7x less than xlsx_raster_width, or write to a different column.
Version: Data interop FME(R) 2021.0.0.0 (20210305 - Build 21302 - WIN64).
Thanks!
hkingsbury
Forum|alt.badge.img+73
  • Jan 31, 2023 7:12 PM UTC
Can you share an example of your workspace? Also might be worth reaching out to support
