write utf-8 attribute PythonCaller
  • Jan 8, 2016 3:59 PM UTC
  • 116 views
jorge_vidinha
Im reading a txt file inside a PythonCaller with some special charaters in.
on the close method when i print line i can see all charaters are fine in log file.
When i pyoutput(feature) encoding gets lost. see my bit of code below
Wondering if some one have an elegant solution to pyoutput attributes in correct encoding (utf-8) without make use o python 3 interpreter or needing to import external librarys.
Thanks all
import fmeobjects
import sys, os, csv, codecs
class FeatureCreator(object):
    def __init__(self):
        self.delimiter = '|'
    def input(self, feature):
        self.fileout = 'file.txt'
    def close(self):
        feature = fmeobjects.FMEFeature()
        reader= codecs.open(self.fileout)
        for line in reader:
            print line
            feature.setAttribute('output', line)
            self.pyoutput(feature)
  • Jan 8, 2016 4:08 PM UTC
Hi
Is "file.txt" saved as UTF-8? If so, you could try to cast the "line" object as unicode before you set the attribute:
feature.setAttribute('output', unicode(line))
When sending text to the FME log window (using print of the FMELogFile-object), just remember that it will be output in cp1252 (or whatever your local codepage is) and not UTF-8!
David
jorge_vidinha
  • Jan 8, 2016 4:30 PM UTC
Hi
David
Thanks for the support David,
Yes file.txt its UTF-8 with out BOM
Using the unicode() i get the error below
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 6: ordinal not in range(128)
  • Jan 11, 2016 9:01 AM UTC
Hi
David
when you import text in a code you should always decode it (when you know  the encoding of the source) here is 'utf8':
line=line.decode('utf8')
and when you export text you should always encode it in the encoding of the target:
line=line.encode('the encoding of the table').
Hope it helps
Hope it helps
