Write to Raster dataset from asci files
  • Jun 12, 2023 3:14 PM UTC
  • 101 views
sunsilk11
Hi, I am reading a bunch of asci files and use a raster mosaicker and trying to write to a raster or mosaic dataset.
I have trued seting creating new attributes geodb_raster_path set to fme_dataset and geodb_raster_type to 'Raster'. or 'Raster Catalog'
I am getting error message:
The raster type 'Raster Catalog' for mosaic dataset 'zzDataset' is not supported by the installed ArcGIS version
  • Jun 12, 2023 3:38 PM UTC
Is there a particular reason for manually setting the value of "geodb_raster_type"? Have you tried not defining it? Same goes for "geodb_raster_path", I don't think you need to set it yourself.
sunsilk11
  • Jun 12, 2023 5:09 PM UTC
Without setting the values, I get following error instead:
Unable to retrieve path to raster dataset from feature
BADNEWS: GEODATABASE_SDE_MOSAIC_DATASET writer: A fatal error has occurred. Check the logfile above for details
(C:\\code\\fme\\foundation\\pluginbuilder\\pluginbuilder_cpp\\dynawch.cpp:132) class StatusInfo *__cdecl DynaWriteChannel::putFeature(class STFFeature *&)
Exception Name: stk::ex::Throwable
RasterMosaicker (RasterMosaicFactory): Failed to output the feature with the mosaicked raster
RasterMosaicker (RasterMosaicFactory): BADNEWS: BADNEWS: GEODATABASE_SDE_MOSAIC_DATASET writer: A fatal error has occurred. Check the logfile above for details
RasterMosaicker (RasterMosaicFactory): Exception Name: stk::ex::Throwable
  • Jun 12, 2023 8:22 PM UTC
The "BADNEWS" entries in the logs can (more or less) only be interpreted by the developers at Safe. If that's the only error you get, consider getting in touch with your FME reseller for support.
Otherwise, can you perhaps share the workspace, minus passwords and the like of course, and the complete log with the error message, that would be helpful.
