Write hyperlinks to Word document with pyhon docx in PythonCaller
  • November 23, 2022
  • 5 replies
  • 1778 views
egge
Forum|alt.badge.img+14
I would like to share a solution to an issue I had, just to hear what you think about it. The challenge is: to create hyperlinks in a Word document.
FME allows you, with the use of MSWordStyler transformers, to create a Word document in a very versatile and easy manner. These transformers, however, do not allow you to insert hyperlinks into the doc.
Please see the attached zip file hyperlinks-to-word-python-docx.zip for a workflow where the document is created using MSWordStylers, followed by some post-processing with a PythonCaller to insert the hyperlinks: POIs with a link to Google Maps, in this case.
No, I did not write all of the Python script myself, hell, no! I used some existing bits and pieces and tweaked them a little bit to get the job done.
The add_hyperlink function was found on github and the docx_find_replace_text one on stackoverflow and I only modified them slightly to work together to replace my search text, the POI name, with a clickable hyperlink. More than 150 lines of code... but it gets the job done.
What do you think? Any comments and test results are appreciated.
Cheers,
Egge-Jan
Edit 2024-04-05: just noted today that the attachment to this post has disappeared with the transfer to the new community environment. I have added it again, this time in a zip file.
virtualcitymatt
Forum|alt.badge.img+35
Awesome thanks for sharing - you should definitely make this into a CustomTransformer!
Forum|alt.badge.img+34
  • November 28, 2022
Nice!
Probably slightly more efficient to build lists of the POI and the replacement links and send that into the python caller and then do something like this
docx_file_path=feature.getAttribute('_dataset')
        document=docx.Document(docx_file_path)
        replace_list = list(zip(feature.getAttribute('_list{}.POI'),feature.getAttribute('_list{}.Link')))
        #search_text=feature.getAttribute('POI')
        #replace_text=feature.getAttribute('Link')
        for search_text,replace_text in replace_list:
            docx_find_replace_text(document, search_text, replace_text)
        document.save(docx_file_path)
egge
  • November 28, 2022
ebygomm wrote:
Nice!
Thanks for the suggestion. Yeah, in this example we are only talking 3 features, but when this number increases your list-approach might indeed be more efficient. Will have a look into it... when time permits...
egge
  • December 12, 2022
ebygomm wrote:
Nice!
Hi @ebygomm​ ,
I have had a look at your suggestion and updated the workspace accordingly. Please see fmwt (version 2) attached. Now a list is created before the PythonCaller is called. In this way there is only the need to process 1 feature, instead of multiple, in the Python script.
Cheers,
Egge-Jan
egge
  • April 5, 2024
Hmmm, just noted today that the original attachment to this post, a Template (*.fmwt file) has disappeared from this post with the transfer to the new community environment. 😕
I have added the example again, both the workspace and an input csv file, but in a zip file this time. See the original, edited post above. 🙂
Cheers,
Egge-Jan
