Write all text from DWG into JSON or XML
I am currently trying to archive information out of old DWG files in my company. But so far I am still rather uncertain with how I open the DWG files in FME in a way, that I can access the labels within the DWG file and write them into another file format.
I found a lot of tutorials with how to write into DWG, but nothing much the other way around.
Can someone help or point me in the right direction?
Forum|alt.badge.img+50
You can set up a DWG reader and have it group by Geometry Type (via the parameters), then you can simply only select the texts.
Then adding a JSON or XML writer should, in principle, do the trick.
  • June 29, 2023
Thank you for your answer.
Okay, I did that and I have the texts now, but when I write it, I get all the meta information in the XML, but not the actual content of the text.
This is what the text layer looks like in inspection.
what_it_looks_like
But this is the write output.
what_it_writesAnd what I want is the actual text. So like the MB07+MB09 and so on.
what_it_looks_like
The text string is stored in an attribute called fme_text_string, which is hidden by default, you can use an AttributeExposer to make it visible (also make sure to add it to the output feature type)
