WorkspaceRunner doesn't allow attribute values to be assigned to parameters in a group
  • Sep 16, 2022 3:50 PM UTC
  • 103 views
aegman
Forum|alt.badge.img+3
This isn't so much a question as pointing out a minor issue.
The WorkspaceRunner transformer (FME 2022.1.2) doesn't allow the user to select an attribute value for the value of a parameter in the workspace to be called if that parameter is in a group:
Parameter accepts attribute valueGroup parameter doesn't accept attribute value
Best answer by markatsafe
@Andy E​ Thanks for attaching the workspace. It does look like there is a backward compatibility issue with the Geometry Box parameter. We'll see if it can be fixed. In the meantime I think you'll have to remove and add back the max/min parameters
@Andy E​ I couldn't see this behaviour in FME 2022.1. There might be something about the Maximum Lat/Long parameter configuration that is preventing the selection of the attributes. Can you attach a copy of your parent and child workspaces? If you prefer you can send them directly to me at mark at safe dot com.
aegman
  • Sep 20, 2022 8:09 AM UTC
@Mark Stoakes​ You're right, I'm not able to recreate the issue with a new workspace using the same parameter configuration, it seems to be specific to the workspace attached. It was created with an earlier version of FME2022, and has also been edited on both Windows and Mac.
  • Sep 20, 2022 8:28 PM UTC
