WMS to Shapefile conversion
  • Apr 12, 2018 2:43 PM UTC
  • 6 replies
  • 543 views
Hi i downloaded FME Trail version and using Workbench. And I am trying to convert WMS "link" to shapefile format.
It is reading well but, while writing into shapefile it is throwing error. See the below error information
"A fatal error has occurred. Check the logfile above for details
FME Session Duration: 2.8 seconds. (CPU: 0.2s user, 0.1s system)
END - ProcessID: 4020, peak process memory usage: 40856 kB, current process memory usage: 39564 kB
Program Terminating
Translation FAILED."
Please help me regarding this issue.
@vamsi krishna
danilo_fme
Forum|alt.badge.img+58
  • Apr 12, 2018 2:53 PM UTC
Hi @vamsi,
Could you send the link to test?
Thanks,
Danilo
  • Apr 12, 2018 2:58 PM UTC
Normally, a WMS returns a raster, but shapefiles don't support rasters.
Can you perhaps explain your requirement in more detail?
  • Apr 13, 2018 5:34 AM UTC
Hi Danilo,
I am trying get shapefiles from WMS and WFS links. Datasets reading from the respective links, while writing into shapefile or geodb format it is throwing error or some times no entitties writing in the shapefile. Here i am attaching the link below.
https://geoportaal.fryslan.nl/arcgis/services/ProvinciaalGeoRegister/PGR2/MapServer/WMSServer?request=GetCapabilities&service;=WMS
https://geoportaal.fryslan.nl/arcgis/services/ProvinciaalGeoRegister/PGR2_features/GeoDataServer/WFSServer?request=GetCapabilities&service;=WFS
danilo_fme
  • Apr 13, 2018 11:52 AM UTC
Hi Danilo,
Hi @vamsi
First I created a Workspace to read the WFS and Write in Geodatabase.
Some layers from WFS doens't has features. Geodatabase layers:
Attached the Workspace - workspace-wfs.fmwt
I'm checking now the WMS.
Thanks,
Danilo
danilo_fme
  • Apr 15, 2018 11:23 PM UTC
Hi @vamsi,
Did you check the workspace with WFS format that I attached?
Thanks,
Danilo
lars_de_vries
Forum|alt.badge.img+10
Hi @vamsi,
You are trying to read from a ArcGIS Server. You can also use the ArcGIS Server Feature Service reader and adjust the URL to
https://geoportaal.fryslan.nl/arcgis/rest/services/ProvinciaalGeoRegister/PGR2/MapServer/
I guess you won't have a problem writing to Shapefile then.
