Why doesn't my regex expression work?
  • Jul 21, 2023 5:34 AM UTC
  • 8 replies
  • 82 views
williamlin98
Forum|alt.badge.img+8
I am trying to extract the 1st and 4th word but it just keeps grabbing the first 4 words, I've tried without the ^ and it doesn't workregexinquirng
tomfriedl
Forum|alt.badge.img+14
  • Jul 21, 2023 6:05 AM UTC
RegEx show you the match string. The string to extract in brackets return by the list "Subexpression Matches List Name" (Transformer Stringsearcher).
geomancer
Forum|alt.badge.img+71
  • Jul 21, 2023 9:00 AM UTC
Use a StringSearcher. Let your regex find all words. Write all matches to a list. Item 0 of the list contains the first match (you can also write the first match to an attribute in the StringSearcher), item 3 of the list contains the fourth match.
StringSearcher
Forum|alt.badge.img+54
  • Jul 21, 2023 9:22 AM UTC
StringSearcher
If using the StringSearcher, you can use the Subexpression Matches List Name and that will return just the 1st and 4th words as two list items(the items within the brackets in the regex)
geomancer
  • Jul 21, 2023 9:40 AM UTC
StringSearcher
Which would look like this:
StringSearcher2Thanks, I never knew this
tomfriedl
  • Jul 21, 2023 9:48 AM UTC
I'm writing this in the first answer ...
sameer
Forum|alt.badge.img+23
  • Jul 21, 2023 10:06 AM UTC
@williamlin98​ Attach is a workspace which I hope provides you with another alternative solution. As others have suggested, you will still need to create a list. It seems to me that the value of your attribute is separated by hyphen. If that is the case then splitting your attribute value works out better.
  • Jul 21, 2023 10:09 AM UTC
You can also extract the first and fourth words within an AttributeCreator/AttributeManager using the StringFunction @SubstringRegularExpression. The 1 and 2 in these expressions refer to the 1st and 2nd match groups image
williamlin98
  • Jul 23, 2023 10:05 PM UTC
Thanks for the answers everyone, helped heaps <3
