Why batch deployment with recreate folder structure is not working 100% perfect?
  • Aug 17, 2022 1:35 AM UTC
  • 89 views
smfks911
I have designed a dynamic workspace to have a bulk transformation on all shape files within a nested folder structure. I have added the original folder location in the reader with checking tick mark for subfolder. Then I have used batch deployment and checked the 'recreate folder structure'. However, the destination files were not written in the similar folder structure as in the original structure.
See how the subfolders within original Asset folder (image 1) were written outside the destination asset folder (second image). Can anyone tell me what was the likely source of this?original_folderrecreated_folder
gisrunner
Participant
  • Participant
  • Mar 28, 2024 12:43 PM UTC
A bit late to the party, but I have run into the same problem. Have you found a solution to this problem in the meantime?
