Why are my polygon holes filled while writing to GDB?
  • Nov 29, 2023 8:44 AM UTC
  • 5 replies
  • 109 views
jugoslaviaa
I have a gdb with polygons ( multipolygons). I read polygons and simply write to a new gdb and my polygons holes are filled? It happens also while reading Isee. As if there is a geometry validation happening.
How can I stop this? It is really annoying.
grafikgrafik
jugoslaviaa
  • Nov 29, 2023 8:57 AM UTC
Okay. I also see. It also fills it while reading some donut polygon. How can i avoid this?
  • Nov 29, 2023 9:28 AM UTC
Hi @jugoslaviaa​ ,
I'm guessing that the orientation of the hole polygons could be wrong. Try setting "Orientation and Spatial Relationship" to the Donut Geometry Detection parameter of the GDB reader.gdb-reader-parameters
jugoslaviaa
  • Nov 29, 2023 9:36 AM UTC
You save my day sir!
jugoslaviaa
  • Nov 29, 2023 7:19 PM UTC
@Takashi Iijima​ It solved the problem while reading gdb however it still occurs while writing. I dont see the similar setting in the writer. Can you also help me wth this?
  • Nov 29, 2023 9:00 PM UTC
I wasn't able to reproduce the situation, but it might be an issue in a specific version of FME.
Try using Orientor (Orientation Type: Left hand rule or Right hand rule) to correct the orientation before writing.
