Why are block unrotated when converted from dgn (Microstation) to dwg (Autocad)?
joy
Forum|alt.badge.img+15
Hello everyone,
I am trying to convert dgn (Microstation) to dwg (Autocad), but for some reason the blocks are in my dwg unrotated. In Microstation those are called cells. Does anyone know how I can get the cells rotated in the dwg file? The igds_rotation attribute does show the rotation values in case of Microstation (see below for some example values)and I read somewhere online that the attribute name that holds the rotation value in case of autocad was 50. I could be wrong though. In the output (dwg) the cells are unrotated. It might thus be due to the fact that I stored the rotation value for autocad under the wrong name.
afbeeldingafbeelding
Best answer by joy
redgeographics wrote:
If you map igds_rotation to autocad_rotation (using an AttributeManager for example), does that work?
I found the solution.
I defined the autocad_rotation in the DWGStyler instead of the Attributemanager and then it worked.
I have no idea why it works in the DWGSyler, but not with the AttributeManager.
Forum|alt.badge.img+50
joy
  • March 17, 2023
Unfortunately it still doesn't work
I saw that someone had a similar problem and an employee at SAFE suggested the following transformer : ReprojectAngleCalculator
However, I have really no clue how to use the ReprojectAngleCalculator and if this might solve the problem
joy
  • March 22, 2023
