Whriter entity issues in a dwg file under FME 2018
  • Apr 13, 2020 4:13 PM UTC
  • 79 views
Hello, I have an input and output dwg file, can you explain to me how to have the same number of entities in Reader and Whriter? Because I get my total of entities (6364 entities) in Writer for each layer while I would like the same number of entities in each layer in Writer as in Reader.
daveatsafe
Forum|alt.badge.img+24
  • Apr 13, 2020 6:25 PM UTC
Hi @lucas,
Please try adding a FeatureTypeFilter transformer to route the features to the appropriate output port.
  • Apr 14, 2020 8:41 AM UTC
Hi @lucas,
Thank you very much it works correctly nevertheless it caused a problem that I did not have before, that created several entities as on the attached photos: layer without the featuretypefilter: Picture7.PNG
with the featuretypefilter:Picture6.PNG
Do you have a solution to this problem? the entities added are of the same layer: E_PRO_SUPPORT
Here is my FME file : FME_Transformation.fmw
daveatsafe
  • Apr 14, 2020 3:53 PM UTC
Hi @lucas,
Please try setting the reader parameter 'Explode Blocks' to No.
  • Apr 14, 2020 6:50 PM UTC
Hi @lucas,
Thank you very much you are a genius it works niquel! Sorry I'm a beginner.
Would you be how to merge the linear array of a dwg file to form a single polyline. I had thought of NetworkTopologyCalculator I do not know what you think?
After having combined (merge) the linear network all together, I have to put it in the same direction and after that I cut it at the points that belong to the layers of my dwg file that I specify. I would tend to use Linecombiner or LineExtender. If you have an idea of how to proceed I am a taker? In all thank you again for your help
