From the first image, you can see the selected object has 6 chairs, which is decided by the number of the visibility. But after translated it into MapInfo, all the options of the visibility (3,4,5,6,7,8) have been translated and overlapped each other. I want the number of chair on each object displayed on MapInfo are the same as displayed on CAD file. Anywhere I can adjust apart from Explode Blocks on FME? Help please! Thank you!!
While translating a AutoCAD file to MapInfo, how to keep the number of object defined by the Visibility number assigned on to the Dynamic Block objects?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
