How to expand Query String Parameters dialog in HTTPCaller?
  • Jul 30, 2025 4:54 PM UTC
  • 135 views
aaron
Forum|alt.badge.img+12
I’m stringing together a bunch of HTTPCallers, each of which has several query string parameters. From what I can see, you are only able to see two parameters at a time in an HTTPCaller transformer (see screenshot). Is there a way to enlarge/expand the dialog box so I can see all or most of them at once? Should be easy;Β I feel like I’m missing something. It would be so much easier, helpful, and efficient so see all query string parameters at a glance. (FME Desktop 2023.2.0.0, Build 20231201).
Best answer by crutledge
Hi ​@aaronΒ I think in this case it is a case of all the other expandable lists fighting for real-estate. I closed all the other optional menus and expanded the height of the HTTPCaller Parameter box. It will expand but not explicitly. I would maybe make a suggestion for that.
But I hope for now this helps!
Β
Β
crutledge
Forum|alt.badge.img+55
  • Jul 31, 2025 12:01 AM UTC
Β
Β
jkr_wrk
Forum|alt.badge.img+37
  • Jul 31, 2025 8:37 AM UTC
Nice improvement since 2021:
Let’s resize the HTTP Method: GET selection and not the Query String Parameters box. 😁
Β
Β
aaron
  • Jul 31, 2025 3:50 PM UTC
Thanks ​@crutledge, that helps. It’s a bit unwieldy because you have to collapse the other dialog boxes every time you open the transformer. In addition,Β I can still only see a maximum of 7 parameters (which is usually fine). Still, an improvement from before!
salvaleonrp
Forum|alt.badge.img+23
  • Aug 1, 2025 10:46 PM UTC
Thanks for the tip ​@crutledgeΒ I have also struggled with this one. Forgot if I submitted an Idea to expand it in the past but I’ve managed to be patient with having two or using the scroll bars. πŸ˜€
