Which transformer do I use to join a query(from data lake) in the SQLExecutor to an existing GIS featureclass?
  • Jun 26, 2023 8:27 PM UTC
  • 76 views
juneacosta
Hello everyone,
I'm a beginner in FME and need some help. I'm trying to join (1:1) data from our datalake with an existing GIS layer. My goal is to append the result of this join nightly to another existing layer. I've attempted to use SQLExecutor to query multiple tables in the datalake and DatabaseJoiner to join the query table with the GIS layer, but it doesn't seem to be working.
Any suggestions or advice would be greatly appreciated. Thank you!
nielsgerrits
Forum|alt.badge.img+67
Can you elaborate what kind of database you have?
juneacosta
  • Jun 27, 2023 3:19 PM UTC
Both the datalake and the GIS db are MSSql.
I attached an image of my workflow. After exporting the GIS layer to an Esri file geodatabase, I used SQL creator for querying the datalake. Then, I attempted to use the FeatureJoiner to join the tabular data from the datalake to the file geodatabase layer. Unfortunately, the FeatureJoiner keeps failing and I'm encountering the following error.
FeatureJoiner_<Rejected> (TeeFactory): FeatureJoiner_<Rejected>: Termination Message: 'FeatureJoiner output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
evieatsafe
Forum|alt.badge.img+28
  • Jun 30, 2023 7:11 PM UTC
Hi @juneacosta​ What's the rejection message for the feature that was rejected? fme_rejection_message
If you turn on 'Continue Translation' in the Rejected Feature Handling do you get the desired result?
