Which Tester operators are case sensitive?
tim_wood
Forum|alt.badge.img+8
At the excellent FME conference in London yesterday, I thought @1spatialdave said he used Contains in a Tester because it wasn't case sensitive. I've been doing @LowerCase(@Value(myAttr)) for some tests where I'm not confident of the case of the value I'm testing. So I'm interested to know which Operators are case sensitive and which are not. For example, if my value is "COMPLETED", I presume that myAttr = "completed" will not match. But will myAttr LIKE "completed" match?
It would be great not to have to worry about doing @LowerCase()...
If some operators are case sensitive and some aren't, please can we have this on the Tester help page. If it's already available, please it be linked to from the Tester helop page.
Depending on the answer to this, I'll vote on
https://knowledge.safe.com/idea/24357/case-sensitive-option-when-testing-attribute-value.html
  • March 24, 2017
Let's test one by one!
The = operator works with case sensitive, in FME 2016 and 2017.
Next please :-)
  • March 24, 2017
Great idea making this a group effort, @takashi. I'm also looking forward to a contribution from @tim_wood ;-)
The "Like" operator is case INsensitive, in FME 2016 and 2017.
Next!
tim_wood
  • March 24, 2017
Ha ha! I kind of thought someone at Safe or one of the resellers would just know...
My contribution is that LIKE is not case sensitive (tested with attribute (Left) Values of "Completed", "COMPLETED" and "completed"; and Tester Right Values of "Completed", "COMPLETED" and "completed"). So that will do me for now.
It would still be good to have it in the Operators section of the Tester help page.
  • March 24, 2017
Hey, that's cheating, you did the same operator as I did ;-)
tim_wood
  • March 24, 2017
Next!
Snap! Although I only tested in FME 2016.1.
@sander_s I think LIKE is the solution you want.
gio
Forum|alt.badge.img+15
  • March 24, 2017
[regexp -nocase {regexp} {teststring}] = 1
and LIKE is indeed not cs.
tim_wood
  • March 24, 2017
Sorry - I posted before I received the email and hadn't refreshed the page either! As @1spatialdave said yesterday it's an average of 2 mins before a response here.
Technically my post wasn't identical to yours i.e. my post LIKE your post rather than my post = your post!
  • March 24, 2017
Yes, you have to be quick around here!
tim_wood
  • March 24, 2017
Contains is not case sensitive.
erik_jan
Forum|alt.badge.img+18
  • March 24, 2017
It would be so nice if this information is included in the HELP for the transformer!!!!
tim_wood
  • March 24, 2017
I've emailed Safe
geosander
Forum|alt.badge.img+7
  • March 24, 2017
Maybe, yes! Although I'd like to do some tests first. But thanks for the heads up :)
brianatsafe
Forum|alt.badge.img+11
Thanks @erik_jan for the suggestion and everyone else in this thread for your dedication to finding the answers. I've filed a request for our doc team to take a look at adding this information. Your crowdsourcing will be a wonderful help.
I will let you know when the documentation has been updated.
tim_wood
  • March 24, 2017
I guess it depends what sort of LIKE LIKE is like? Is it like T-SQL LIKE?
geosander
  • March 24, 2017
Wow, that's a lot of likes in one sentence! :)
But yes, my point exactly.
'In' is case sensitive in FME 2016 and 2017
  • March 25, 2017
Yes, the In operator is case sensitive if the right operand is a comma separated values. However, interestingly, it is not case sensitive if the right operand is a range expression (min-max).
"String ranges (i.e. a-d) can also be specified." -- Help on the Tester
Case Sensitive
Left ValueOperatorRight ValueOutputbIna,b,cPassedBIna,b,cFailedbInA,B,CFailedBInA,B,CPassedCase Insensitive
Left ValueOperatorRight ValueOutputbIna-cPassedBIna-cPassedbInA-CPassedBInA-CPassed
Case Sensitive
Well, that is confusing....
  • March 29, 2017
OK. I shall complete the work.
!= > < >= <= are all case sensitive.
Begins With and Ends With are case INsensitive.
Contains Regex (FME 2016.1+) and Matches Regex (FME 2016.0) are case sensitive, although the Regular Expression Editor for them works always with case INsensitive...
brianatsafe
Hi All,
We have updated the documentation as of b17460. Thanks for all your help.
"The operators Like, Contains, Begins With, and Ends With are not case sensitive. The other operators are case sensitive."
Thanks!
  • May 3, 2017
brianatsafe wrote:
Hi All,
Thanks!
Hi @BrianAtSafe, thanks for the update on the help doc.
It would be better if the Regular Expression Editor for the Contains Regex opertor could work in case sensitive so that it would be consistent with case sensitivity of the operator.
