What's the process to rename FME PlugIn Java SDK classes?
  • Apr 11, 2018 5:09 PM UTC
  • 104 views
The documentation "FMEPlugInSDK_Java.pdf" refers to a script "rename_format_java.py" that presumably renames classes and files so you can build your own custom plugin.
Where is this file? It does not appear to be installed (though similar corresponding scripts for C++ and Python plugins are present).
Best answer by nathanatsafe
Hi @neilhellas,
It looks like our documentation has gotten ahead of our code in the last half-year, and this part of the documentation is now defunct. Please open a case here: https://www.safe.com/support/report-a-problem/ so that our integrations team can work with you to get you started. Sorry for the inconvenience!
Best,
Nathan
nathanatsafe
Forum|alt.badge.img+9
  • Apr 11, 2018 6:12 PM UTC
Hi @neilhellas,
Best,
Nathan
