Vertical Datum reprojection
I have a bunch of North American data points that reference NAVD 27, 83 and WGS 84 ellipsoid for elevations. How can I utilize FME to reproject the vertical data so it references the WGS 84 geoid (EGM96) instead of its current vertical datum?
Best answer by fmelizard
To reproject your data from the specified vertical datum to EGM96, you need to do a combination of one or more of the following transforms: WGS84 ellipsoid -> EGM96 CsmapReprojector with these settings:
vertical handling: 'Geocentric or ellipsoid height -> Orthometric Height', Geoid height grid: FME_HOME\\Reproject\\GeoidHeightGrids\\World\\Egm96-Wgs84.gdc
LL84 as both source and dest CS NAVD83 (assuming this means NAD83+NAVD88) -> WGS84 ellipsoid CsmapReprojector with these settings:
vertical handling: 'Orthometric Height -> Geocentric or ellipsoid height', Geoid height grid: FME_HOME\\Reproject\\GeoidHeightGrids\\Usa\\Geoid*-Nad83_Navd88-*.gdc, (source CS: LL83 -> destination CS: LL84) NAVD27 (assuming this means NAD27+NGVD29) -> NAD83+NAVD88 CsmapReprojector with these settings:
vertical handling: 'NAD27 heights in NGVD29; NAD83 heights in NAVD88', Source CS: LL27 -> Destination CS: LL83 (more steps required if horizontal and vertical datums are not currently in sync)
So, to go from NAD27+NGVD29 to EGM96 you need to do 3 vertical transforms in this order:
NAD27+NGVD29 => NAD83+NAVD88 => WGS84 ellipsoid height => EGM96
NAD83+NAVD88 => EGM96 requires 2 steps:
and WGS84 ellipsoid height => EGM96 is just one step.
Hope this helps.
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
