Validate URL from Excel
  • Dec 16, 2021 7:55 PM UTC
  • 245 views
hugues
Hi. I have a xlsx file with a field containt Path to a PDF. I want to validate if the PDF of the path exist. Can you help me. Thank you.
hkingsbury
Forum|alt.badge.img+73
  • Dec 16, 2021 9:12 PM UTC
hugues
  • Dec 17, 2021 1:40 PM UTC
I can't run the transfomer ? it's all stay gray...
drc43
Forum|alt.badge.img+13
  • Dec 17, 2021 2:42 PM UTC
What version of FME are you using? The Hub page says it requires FME 2020.0.2.1 (Build 20238) or higher.
caracadrian
Forum|alt.badge.img+23
  • Dec 17, 2021 5:41 PM UTC
I have posted a FME transformers only solution to your other thread: Compare a XSLX field with folder with PDF (safe.com)
