Using the IN operator in a TESTER
  • November 21, 2013
  • 116 views
moberdries
Forum|alt.badge.img+7
Does the IN operator in the TESTER extend to working with string elements as well as numbers?  The FME help documentation shows a number example (below) but I would like to search a string element list:
Help example:
X=5, is X In 1,2,3 (no = FAIL)
Why can't I do this:
X=hello, is X In hello,goodbye (yes = PASS)
I am running FME2012 (SP0) if that is the limiting factor?
I have tried quoting the string elements?
I have tried a regex operator using the (hello|goodbye) syntax?
I have an attribute that I want to filter on 10 or so qualifying values - I could build a lengthy OR statement in TESTER but I was hoping for a simpler workaround.
moberdries
  • November 21, 2013
Hmm ... looks like one workaround is to use the StringSeracher with a regex that looks like this:
^(hello|goodbye)$
Still doesn't explain why "IN" in the TESTER does not work for me or why the same regex notation does not work with the TESTER?
Haven't had a chance to test this with a later FME build.
Mike
  • November 21, 2013
Hi Mike,
I use FME 2013 SP4 and the IN operator works well with your examples.
Thomas
