Using Python to delete files in a directory
fmelizard
Forum|alt.badge.img+19
Hi Folks,
I want my workspace to clean up after itself. It creates a number of files in a temporary location, which is specified in a parameter: [FANOUT_DIRECTORY], which points to:
C:\\TempData\\translation_temp
Using FME 2014, I want to get python to delete all fines within this.
In theory, I need something like this:
#remove the text files
import os;
def FeatureProcessor(feature):
folder = str(FME_MacroValues['FANOUT_DIRECTORY'])
for the_file in os.listdir(folder):
  file_path = os.path.join(folder, the_file)
  try:
   if os.path.isfile(file_path):
    os.unlink(file_path)
  except Exception, e:
   print e
However, the value for "folder" when it gets the parameter FANOUT_DIRECTORY is:
C:<backslash>TempData<backslash>translation_temp
Which is obviously wrong. Anyone know how to get a parameter properly such that I can just use it? The examples I've seen don't appear to have this problem (but Python-FME documentation is sparse and conflicting).
Thanks.
Best answer by david_r
Btw, starting with FME 2014, you can also use the following method from the fmeobjects API:
folder = fmeobjects.FMESession().decodeFromFMEParsableText(FME_MacroValues['FANOUT_DIRECTORY'])
(If I'm not mistaken...)
David
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • August 11, 2014
there are several solutions to this, but the easiest is perhaps:
folder = str(FME_MacroValues['FANOUT_DIRECTORY']).replace('<backslash>', '\\\\')
David
  • August 11, 2014
David
fmelizard
  • August 12, 2014
Hi David,
Thanks, the second one works like a charm!
