Using Ingres X Spatial DB and getting "FME Configuration: No destination coordinate system set Invalid WKB encountered.
  • Apr 26, 2017 2:18 PM UTC
  • 5 replies
  • 95 views
Using Ingres X Spatial DB and getting "FME Configuration: No destination coordinate system set Invalid WKB encountered. Ingres: invalid WKB encountered " The table has been created with srid 26911 and data inserted with the same srid. In FME the Coord system shows EPSG:26911. Any ideas on what is going wrong ? Using the Ingres table in reader and writer features.
Transformation log
ME Configuration: Source coordinate system for reader com.actian.ingres.ingres_1[COM.ACTIAN.INGRES.INGRES] set to `EPSG:26911'
Coordinate System `EPSG:26911' parameters: CS_NAME=`UTM83-11'
FME API version of module 'LogCount_func' matches current internal version (3.8 20170315)
Creating writer for format: FME Feature Store (FFS)
FME Configuration: Using FME Reprojection Engine
FME Configuration: Using Named Connection values from 'mapr2-II' for com.actian.ingres.ingres_2
Creating writer for format: Actian Ingres Spatial
Trying to find a JAVA plugin for writer named `com.actian.ingres.ingres'
FME Configuration: Destination coordinate system set to `EPSG:26911'
Ingres: failed to prepare column shape, null
ravenkopelman
We have not tested against the latest versions of Ingres. Please create a ticket with support@safe.com, and reference PR#77563
  • May 17, 2017 6:28 AM UTC
Done, thanks
  • Oct 24, 2019 2:14 PM UTC
Any update ?
brianatsafe
Forum|alt.badge.img+13
Any update ?
Hi Dean. Sorry to say there is no update at this time. Please feel free to reach out via your support case with us and we can look into any next steps or add any new information to the ticket. Thank you.
