Using IN operator with tester transformer
  • February 12, 2024
  • 125 views
derekg
Participant
I have a list of lab test results and only want to include the rows that match a list of analytes. I am trying to use the IN operator in the tester transformer.
I have followed the advice from this post:
Help with syntax when using Tester transformer | Community (safe.com)
This is what I have:
Sheet1 contains the test results, text_line_data contains the list of analytes as one feature. I have merged them to get this:
The “text_line_data” column looks like this:
My tester transformer is set up as below:
However, all rows fail the test. What am I doing wrong?
oscard
Forum|alt.badge.img+21
  • February 12, 2024
The IN parameter takes a comma delimited list: A,B,C…
You also need to remove the quotation marks from the list. Do that first and then use an Aggregator transformer to create the list separated by commas.
Forum|alt.badge.img+49
I think the Contains operator, rather than In, does what you want (if you swap the left and right values)
