Using IN command in InlineQuerier
  • Aug 17, 2017 5:20 PM UTC
  • 73 views
I have two datasets that I am currently working on:
1) DBF1
2) DBF2
I need to lookup for Description (in DBF1) in DB2 within the columns I1 to I8 and
>> to return the corresponding DMA to Inflow field if a match is found OR
>> to display a space if no match found
The result would look as follows:
Currently, I am using the InlineQuerier with IN statement, but it truncates the result when there is no match. The NOT IN command displayed irrelevant results as well.
Please suggest a solution which may be SQL or Non SQL based.
Best answer by courtney_m
I was able to get this to work using an InlineQuerier that has 2 output ports. The DMA port outputs all "matched" records, and the DBF1 port outputs all records from DBF1. I used the following SQL statement for the DMA port:
SELECT "DMA","Description","ID"
FROM "DBF1" JOIN "DBF2"
ON "Description" IN ("I1","I2","I3","I4","I5","I6","I7","I8")
Then I used a FeatureMerger (DBF1 = Requestor, DMA = Supplier) that joined on Description. I connected the Merged port AND the UnmergedRequestor port to an AttributeManager (this gives me 1 stream with my 12 original records) - In the AttributeManager, I created the field Inflow, and set it to DMA, if DMA has a value. Otherwise, Inflow is set to a space. Then I removed the DMA field.
This is the output I got:
Here is a screenshot of the entire workspace:
And a screenshot of the AttributeManager properties:
I have also attached the workspace, in case you want to look at it.
Originally, I was going to output the "non-merged" features through another port of the InLineQuerier, but I also was unable to get the NOT IN statement to work successfully. This process is a little clunkier, but it works.
-Courtney
courtney_m
Forum|alt.badge.img+23
  • Aug 17, 2017 8:12 PM UTC
-Courtney
  • Aug 17, 2017 10:33 PM UTC
This SQL statement could also be a possible way.
select
    a.*,
    case
        when b.DMA is null then ''
        else b.DMA
    end as Inflow
from DBF1 as a
left outer join (select * from (
    select DMA, l1 as Description from DBF2
    union all select DMA, l2 from DBF2
    union all select DMA, l3 from DBF2
    union all select DMA, l4 from DBF2
    union all select DMA, l5 from DBF2
    union all select DMA, l6 from DBF2
    union all select DMA, l7 from DBF2
    union all select DMA, l8 from DBF2
) where Description <> '') as b
on b.Description = a.Description
Alternatively, this Non SQL based workflow could work as well.
