URL's with *blank spaces* to FeatureReader
  • December 20, 2021
  • 600 views
hlynur
Forum|alt.badge.img+8
Hello.
I am trying to run a bunch of online and zipped INSPIRE GML's through a Feature Reader with the dataset parameter set to a URL defined in an attribute.
All is good and stuff is happening for most of the data except the URL's that have a space in them, for example: 'http://www.catastro.minhap.es/INSPIRE/CadastralParcels/02/02024-CASAS IBAÑEZ/A.ES.SDGC.CP.02024.zip'
And those get sent to the reject port with the error message:
XML Parser error: ''Error in input dataset: 'URL' line: 1 column: 50 message: whitespace expected''
I did check out this one here:
How do I remove a non breaking space from an attribute? (safe.com)
But no luck , so any ideas?
Best answer by david_r
Generally speaking, spaces are not allowed in URLs. If the URL works in e.g. a browser, it's because the browser automatically does some work behind the scenes to make it work for you.
Try replacing the spaces with "%20", which represents a URL-encoded space. While you're at it, you may also have to encode the Ñ:
http://www.catastro.minhap.es/INSPIRE/CadastralParcels/02/02024-CASAS%20IBA%C3%91EZ/A.ES.SDGC.CP.02024.zip
You can also use the TextEncoder set to URL encoding, just make sure you don't encode the meaningful characters, such as the forward slash.
  • December 20, 2021
hlynur
  • December 20, 2021
hey and thanks for this, turned out that the space wasn't a problem after all, it was the "weirdo N letter".  And using TextEncoder and setting the attribute to URL failed cause, like you pointed out, replaced all slashes etc..
sigtill
Forum|alt.badge.img+24
  • December 20, 2021
To be "safe" I usually end up doing something like this to urlencode the filename and the previous folder. Using the FilenamePartExtractor + TextEncoder + StringReplacer prepares the url quite good for the FeatureReader.
hlynur
  • December 20, 2021
Nice, thank you as well Sigbjørn & Antonio!
