Updating Text File (.txt).
  • Apr 25, 2022 6:34 PM UTC
  • 264 views
I need to update a text file which contains the settings for an executable tool. It would be really useful if I could automate this in FME.
The text file is saved in UTF-8 format and for example, lines two and three contain the variables for START_TIME and END_TIME:
START_TIME=2005/01/01 00:00
END_TIME=2007/12/31 23:59
How can FME be used to change the two dates, 2005/01/01 and 2007/12/31?
Thank you, Rob
Best answer by dustin
FME reads lines of text as individual features using the Text Reader, and puts the text into an attribute 'text_line_data'. You could then filter the features by 'text_line_data BEGINS WITH START_TIME' AND 'text_line_data BEGINS WITH END_TIME' using a Tester or TestFilter.
I would probably setup two Text parameters in the workspace, one for START and one for END, for which you will enter the desired date/times. Using Regex Replacement in the StringReplacer, the date/time value would be replaced with what is input in the parameters. The resulting workspace would look something like the screen shot below. I don't know the Counter/Sorter is necessary, but it will ensure the lines of text are written in the same order.
dustin
Forum|alt.badge.img+36
  • Apr 25, 2022 6:55 PM UTC
  • Apr 25, 2022 7:01 PM UTC
What transformer would you recommend to filter the features by?
Just seen your update above.
dustin
  • Apr 25, 2022 7:02 PM UTC
I would use the TestFilter. @rob_nason​ You may have to expand the post to see the screenshot.
@rob_nason​ Be careful with TestFilter - it might change the order of your records if you are using FME 2020 or higher:
imageSo either change that parameter to Preserve Feature Order: Across Ports (which might impact performance) OR...
Configure your Text File reader to read the entire file into a single attribute - and then use StringReplacer with a regex on that attribute.image
