Update spreadsheet using FeatureWriter?
  • October 25, 2024
  • 49 views
vxn43
Forum|alt.badge.img+18
Hello,
I am attempting to use the FeatureWriter to update a spreadsheet. From the screenshot you can see I have Addresses Input into which is pushed 3 updates and 95,393 from the original spreadsheet. The Output port, Addresses adds the 3 records to the original spreadsheet making for 95,396 records.
Is there a way to get FeatureWriter to update the spreadsheet so the output is 95,393 with the 3 records in 95,393 updated not added to the output? The FeatureWriter is writing to the same spreadsheet in the Addresses Reader.
Best answer by emma.at.safe
Hey @vxn43,
You can use a FeatureJoiner before the FeatureWriter to join the 3 updated rows to those in the original spreadsheet.
To set it up:
  • Connect your original file to the Left input port and the updated file to the Right input port on the FeatureJoiner.
  • In the parameters, set Attribute Conflict Resolution to Prefer Right.
Hope this helps!
Emma
emma.at.safe
Forum|alt.badge.img+8
  • October 30, 2024
Hey @vxn43,
To set it up:
Hope this helps!
Emma
