Unzip error
  • Sep 17, 2018 11:45 AM UTC
  • 105 views
jatoxa
Forum|alt.badge.img+12
Hi!
I'm making a workspace that reads files and folders and upload/recreate these files and folders on a web location. I can't find a good way to upload entire folders to FME Server when submitting jobs.
Instead I made a solution that uploads and unpacks zip files to get the entire folder structure to the server.
Of course it worked fine with all my own files but when trying a zip file my colleague have made I get the following error using the "ZipExtractor":
ZipExtractor_Terminator(TestFactory): ZipExtractor_Terminator: Termination Message: 'Unexpected error: 'ascii' codec can't decode byte 0x94 in position 32: ordinal not in range(128)'
Error encountered while calling method `input'
ZipExtractor_PythonCaller(PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
Using the Unzipper I get the workspace to run but not all files and folders make it through the transformer.
Does anyone know a workaround? Or even a better way to upload folder structures to FME Server?
Thanks!
  • Sep 17, 2018 1:07 PM UTC
Hi @j2, thanks for using the ZipExtractor.
The error could appear if the version of Python interpreter was 2.7 and a file path to be extracted contains non-ascii characters. Hopefully the issue might be resolved if you set "Python 3.x" to the Python Compatibility parameter for the workspace.
jatoxa
  • Sep 17, 2018 1:24 PM UTC
Hi takashi,
Thanks for the quick reply! And thanks for making the ZipExtractor:)
I thought I had already tried your solution but I had changed to Python 3.x in the general settings instead of the workspace parameters so now it works perfectly!
jatoxa
  • Sep 17, 2018 1:49 PM UTC
I can't seem to get it running on the server though. Do you know if I have to make some configuration here as well?
