Unique values in AttributeFilter end up as one value.
  • Dec 9, 2022 11:34 AM UTC
  • 72 views
timnil00
We have a unique number 0 and 00 to identify paying customer.
I set (0 and 00) in the AttributeFilter but both values end up on either 0 or 00 depending on wich one in the list comes first.
What am i missing here? or should i set up a tester instead for each number or text value?
/Tim
Best answer by david_r
I'm suspecting that the AttributeFilter is using some sort of 'intelligence' to decide whether to make the comparison as string or as an integer. In this case it seems like it's doing an integer comparison: 0 == 00.
If you switch to using the TestFilter, you can force the use of a string comparison: 0 != 00
For example:
  • Dec 9, 2022 12:37 PM UTC
For example:
timnil00
  • Dec 9, 2022 12:49 PM UTC
Okey, well this seems to work, thank you so much :).
2022-12-09_13-43-30
