Trying to use the FeatureReader with AutoCAD drawings. The Title Blocks are not getting read for some reason.
  • Oct 20, 2022 9:58 AM UTC
  • 27 views
nimeshg
The drawing has the title block "fugi tb info". When it's run, it says that autocad_block_name has no value.
Help would be appreciated.
kailinatsafe
Forum|alt.badge.img+24
Hello @nimeshg​, would you please share:
  • What format Reader you're using in your FeatureReader?
  • Which DWG file should contain the block name "fugi tb info"?
  • Lastly, what version of FME are you using?
Happy to help, Kailin.
