Trying cell value based colors in Excel. ExcelStyler is simple and straight forward. Still I am missing some fundamental principle is missing. Attached workbench has very easy example to demonstrate how I mange to create non-formatted excel file
  • Feb 23, 2022 2:34 PM UTC
  • 6 replies
  • 140 views
jakomies
Trying cell value based colors in Excel. ExcelStyler is simple and straight forward. Still I am missing some fundamental principle is missing. Attached workbench has very easy example to demonstrate how I mange to create non-formatted excel file.
Best answer by ebygomm
You need to have the .formatting attributes exposed on the writer
caracadrian
Forum|alt.badge.img+23
  • Feb 23, 2022 3:20 PM UTC
If you use ExcelStyler you have to set Attribute Definition in the writer to Automatic.
You also should set an Else value for the backgroud colour.
Forum|alt.badge.img+54
  • Feb 23, 2022 4:11 PM UTC
jakomies
  • Feb 24, 2022 7:01 AM UTC
Attibute definitio/type doesn't matter.
Else value is not needed. Actually it is better to leave empty because there is 'No Fill' option.
jakomies
  • Feb 24, 2022 7:19 AM UTC
THX!
This solved the issue.
Actually this is forst topic in Formatting section in Excel writer documentation. Somehow I hadn’t internalized the matter.
Interesting is that this example is working without those .formatting attributes in writer side:
https://community.safe.com/s/question/0D54Q000080heIxSAI/style-excel-cell-values (fme2018-beta-excelstyler-example-2.fmwt).
  • Feb 24, 2022 7:25 AM UTC
THX!
In earlier versions of the excel writer it didn't used to be necessary so I expect that is why that example works without​
jakomies
  • Feb 24, 2022 7:38 AM UTC
Correct.
I made 'Update Writer...' to that writer in the example workspace -> value based cell fill no longer works.
