Truncating an Oracle Table Slow even with Drop any table
  • June 21, 2013
  • 35 views
We have to use an ETL account to write to our Oracle feature classes in the geodatabase.  We are using SDE 10.1 on Oracle 11g.
We have granted the ETL account and ETL role DROP ANY TABLE but the writer still behaves like it is doing deletes.  We can make this work in our SQL database but are having problems in Oracle.
What are we missing?  Using the Schema owner is not a option.
Thanks
Deb
Best answer by david_r
try to truncate the table with an SQLExecutor and something like
truncate table myschema.mytable
and see how it compares performance-wise. If this is equally slow, the problem most probably lies outside of FME.
David
  • June 24, 2013
David
